mastamoon »
https://forums.nicoclub.com/mastamoon-u255559.html
Mon Sep 14, 2015 8:06 am
Hey All,
Well I have worked through a few CEL's now since getting this truck a few months ago. Right now I have 1 left that im trying to figure out before I go out and buy a part. Just gotta get this thing through inspection so I can work on fixing all the other stuff.
P0134 HO2S1 (B1) High Voltage
When looking at this sensor in realtime with Torque (android app), I can see some activity.. but its mostly just either 0 volts or 1.27 volts. Checked out the FSM and tried to do some troubleshooting. Found the plug and checked that first, looks ok. I did the ohm measure between pins 1 and 3 and got something slightly higher than the 2.3 to 4.3 spec the manual shows, but it says "77 F" there and the engine might have been warmer than that so I dont know if a 5.x reading would be ok at a higher temp? There was also no continuity between 1 and 2 and 2 and 3.
The other tests require checking the wires between the plug and the ECM. Im not sure how you are supposed to do this with normal length leads and I was hoping to not have to dig the ECM out of from behind the center console.
Given the results I got testing the o2 side and the readings from my obdII scanner/reader/logger, is it safe to say its 'likely' a bad/going o2 sensor, or could there really be an issue between the o2 sensor and the ECM?
