1 bright come one with my regular lights
mikejax21
Car: q45
when i turn on my lights i have a single bright that comes on along with it i tried changing the bulb but it didnt help any one have any advice?
goody90q45
Car: 1992 Infiniti Q45 (sold)
The obvious response would be to replace the headlamp relay tucked in behind the radiator overflow bottle beside the passenger side fender. But I can also tell you that the first time I replaced one of the micro bulbs in the seat controller I used a metal screwdriver with the lights on to tighten the bulb and burnt the Illumination fuse in the passenger compartment fuse box......and the high beams came on with the headlights. I bought the $80 headlamp relay from the stealership only to find out it was a 50 cent fuse blown.
How are the rest of the interior lights working? How about the tail lights and brake lights? You'll also want to check the sockets in the brake lamp modules and dual filament bulbs for signs of melting. Is there a warning message in the odometer display? If so you'll also want to look at the brake and tail lamp sensor located below the trunk lock for signs of melting in the ground circuit.
See the "Location of Electrical Units" at the end of the EL section of the FSM for locations of the sensors and relays I've mentioned.
http://www.nicoclub.com/FSM/Q45/1995_Q45/1995_Q45/
mikejax21
Car: q45
well i checked all the fuses after i bought the car and thyre all fine(the ones i can find atleast) but my fog lights are out and i have a side marker and a back up light that are out as well but i know those are bad bulbs but i havent checked the fog light bulbs yet
Q451990
It's also possible that you have a bad stalk switch. You would need to check the ouputs with an ohm meter using the wiring diagrams and pin-outs provided in the factory service manual. www.nicoclub.com/FSM/
Heath
