Unless the CAT is damaged and not working, it is illegal for them to put in a new CAT. That will factor into the decision.Coreykrhn wrote:Right, there master tech said i needed it. Now when i get the new engine are they going to put another f****** cat in there??
Do i have a good chance of them replacing my engine for me? It has been there since Thurs and they havent gotten back to me with a decison on what they are going to do theymarlin29311 wrote:
If this is the case, then you should be getting a new motor. If the CAT is messed up as well, they should replace that too.nametakennow wrote:It's a recall issue, even if your car isn't under it (which an 03 should be, but whatever). Nissan owes you a new engine, period.
I missed that day in physic's can you please explain how anything can get sucked up the exhaust?nametakennow wrote:The cat is damaged, so that won't be an issue. It literally disintegrated and was sucked back into the cylinders via the exhaust ports.
On the QR the recall explains it, but basically this is how it works:evildky wrote:I missed that day in physic's can you please explain how anything can get sucked up the exhaust?
