1/8 tank of gas gone in only 3 blocks !!!
wangless
Car: '02 MBP WRX
ive searched... nothing really shows up since the move of servers...
anyway, so every morning before i head off to school i do the same thing. get the car, start it up, let it warm up for about 10 minutes, then drive off. by the time i reach the end of three blocks my gas gauge drops 1/8 of the tank. its pretty whack, i spend about $30 for a tank a WEEK. and i drive less than 150 miles in that one week.
ive changed plug, wires, cleaned tb and seafoamed. i have the o2 sensor, fuel filter, dis and cap to go. and im also throwing the egr and speed sensor codes, would that contribute to my HORRIBLE milage. any additional things that i should change ie. fuel pump, coolant temp sensor ? im just throwing things out... any suggestions would really be helpful. thanks guys
SHIEF
You have to have a fuel leak somewhere or it's the cluster/float on the fuel pump. Have you driven the car till the gas light comes on? If so, then your leaking fuel, or you have an injector sticking open.
wangless
Car: '02 MBP WRX
ive driven to where the light comes on before. i dont smell any fuel leaks or fumes at all... if its stuck open, how do i get it unstuck ?...
S13ChucKAT
Car: asd
yes, your egr is DEFINATLY constatuting to your bad gas mileage.
PalmerWMD
Car: 2004 350Z
What about the MAF?
I once had a bad MAF caused me to get like 4 mpg with extreme loss of power and a trail of soot behind me.
Do you have these other 2 symtpoms as well?
Fred..
wangless
Car: '02 MBP WRX
i cleaned the maf out with carb cleaner earlier this past month. no really extreme loss of power and no trail of soot behind me...
i guess its time to replace my egr...
anyone else have any other input ?
thanks guys
navysnail
you need to check for the signal coming from the MAF, that will tell you the story on the maf.
also, smell for fuel and the coolant temp. sensor could also do it
10 minutes is a little long for warm up, that could be part of the problem, but not the whole story.
wangless
Car: '02 MBP WRX
how would i go about checking the MAF ?
i dont smell fuel
and like 7-8 minutes for 2 1/2 bars, thats when i usually drive off. if i sit there for 10 minutes itll reach NOT
gogg
Car: 89 240sx silver hatch (burrito)
How would the speed sensor code contribute to bad mileage? I have that code too, so I'd like to know.
wangless
Car: '02 MBP WRX
so last friday i tried to change my o2 sensor, but i didnt have the right tool and left the sensor UNPLUGGED. i drove it until today and finally realized it was unplugged LOL. i rented an o2 sensor tool to remove. hahahaha. good times. anyway, during the 3 days since i left it unplugged, it drove the same -_-. i wonder if this would help my gas milage. but its weird that when the shop ran the codes a month ago only speed sensor and egr popped, not o2.
oh yeah and since friday i got a full tank of gas. today my needle is at the half way mark... ive driven only about 70 miles... ill probably take the car to the shop this week to fix my EGR
IlIkEmYz
Car: 06 Z
i think 3 minutes max is enought to warm the car up.... and for me i don't even warm up i just turn it on.. put on my seat belt... get some beat going and drive.
silkk
Car: 94 B13
89 S13
07 S2000
I warm up it up for 2-3 minutes and then go. :p
maybe 'cause you don't have a zenki lip and its like causing drag so it uses more fuel to make it move.
wangless
Car: '02 MBP WRX
its pretty cold in the mornings... that may be why it takes longer for me. during the afternoon or something it only takes like 5
onosqv
Car: '92 240sx Vert
wangless wrote:its pretty cold in the mornings... that may be why it takes longer for me. during the afternoon or something it only takes like 5
Stop warming up your cars DAMMIT:
http://www.mileone.com/corp/in...s.htm
Well, some sources say this, haha. I know some of you guys swear by warming up the car, and I warm up my car for a good minute, haha.
Yea, unplugged o2 sensors will kill your gas mileage. This is why you need a safc and wideband sensor to monitor these things, haha.
Hope your car gets better dood. Gas is gettin expensive in our areas.
wangless
Car: '02 MBP WRX
if i dont warm up my car.... itll bog and jerk like i dont know how to drive stick !
gabossie
Car: Your mom
This could very well be caused by the EGR. It's worth a check of the MAF too though.
Kinda off topic, but I always meant to ask you if you knew where they found your old car in Pomona.
wangless
Car: '02 MBP WRX
umm... its in the police report somewhere. i faintly remember them saying it was off some road near the police station actually
and back on topic now... how would i go on checking the maf ? i asked earlier but no one really answered it
onosqv
Car: '92 240sx Vert
wangless wrote:umm... its in the police report somewhere. i faintly remember them saying it was off some road near the police station actually
Ummm, maybe you can use a multimeter technique:
http://www.autospeed.com.au/cm....html
Since you already cleaned yours, I'm guessing that may help a little. I'm guessing if you test the voltage it should be between like .6 - .8 for stoic. I'm not totally sure tho, because I know there is a closed loop, which is idle and low rev I think, where it jumps up and down. Then when you slam it, it should start being more consistent and going into open loop mode.
Again, I'm not sure and could totally be wrong .
Hope it helps somewhat.
Also, I think if your MAF is bad, wouldn't your idle, etc also be like crap? I know when my MAF was bad, I didn't just get bad gas mileage, my car would idle like crazy and die.
sil80drifter
Car: 1990 240SX Hatch
When my MAF connector was not properly attached to the MAF sensor, my car would stumble and die at idle, and eat HORRIBLE gas (1/3 tank for like... 10 minutes of driving), unless I went WOT, then it woudl be ok, but at WOT... with boost... ogh it ate even more...
sil80
wangless
Car: '02 MBP WRX
bah brokeAs240sx... i dont want to be a subscriber
onosqv
Car: '92 240sx Vert
wangless wrote:bah brokeAs240sx... i dont want to be a subscriber
freakin a... I was able to get to that article w/o subscribing earlier.
I checked the link just now, and hmmmm, interesting...
onosqv
Car: '92 240sx Vert
pssssttt. I figured out something very sneaky... no one EVER tell autospeed.
***EDITED****
don't want to get in trouble
Modified by brokeAs240sx at 7:49 AM 10/7/2004
wangless
Car: '02 MBP WRX
lol... delete post now...
