That 300 isn't available immediately. You also have a manual, that you can clutch dump.. Also your car doesnt weigh in at 4,300 pounds (with driver)
The Q was never fast off the line...
Case and point.. I raced countless E36 M3s.. 240hp version, sold before the newest one.
Anyway, they would absolutely slaughter me off the line... However, if the race was after 70, it couldn't pull one inch on me..
you would never know the Q45 was as fast as an m3, if you just paid attention to it's off the line performance..
Hitman said he raced an LS430 from a roll, and never lost an inch. The LS400 is a mid 14 second car, with higher 90s traps.. greg ran a
[email protected], yet he didn't have any problems with the LS..
Things change when you don't have to get two tons off the line, with an engine that was built for high rpm performance
E36 m3s run low 14s@high 90s.. 14.2@99 was a common number
If you took the Qs performance from 70+.. it's basically a low 14 second car, with high 90s traps. I can't tell you how many low 14 second cars couldn't pull on me at freeway speeds..
The same is true for the 540i.
The 540i 6 speed will SLAUGHTER an m3, and a Q45 for that matter, on the freeway.
I've witnessed and raced them many times.. yet I could never convince BMW fanboys the 540 was faster then an m3.. all they did was go off the 1/4..
how could a q be as fast as an m3, when it runs 15..
how could a 540 slaughter an m3, when the 1/4s are the same..
dumb fanboys
