nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Feb 28, 2007 7:56 am
Nissan uses tons of slight variations on the same ECU in the same car. For instance, there are 62 ECUs for just an '01 Sentra 2.0.
That said, if you look at the numbers on the back and start calling junkyards, they might be able to find a match.
This car may be subject to an ECU recall. There was an issue with the foam surrounding the ECU. Call a dealer and run the VIN, you may get a new one for free.
