1/8" bsp IIRC plug for sensor port. Oil bracket installation
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
I need to plug the port next to the oil tree. Someone in the past installed the pressure sending unit in that port but now i want to plug that port. A member here said i need an 1/8 bsp plug but i dont know where to get them.
http://www.ebay.com/itm/1-8-x-28-BSP-Ma ... f8&vxp=mtr
Anyone know if this one will work?
Also to those who installed the oil tree with silicone instead on the paper gasket how did you go applying the silicone?
amiry36
You mean the oil pressure sending unit? That someone was Nissan. It came with oil pressure sending unit from factory.
Just out of curiosity, why do you want to plug it?
emiliog2276
amiry36 wrote:You mean the oil pressure sending unit? That someone was Nissan. It came with oil pressure sending unit from factory.
My oil tree was removed for some reason and the pressure sending unit was relocated to some port on the side, i got a replacement bracket and now i need to plug that port since the sending unit is gonna go on the bracket.
