PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sun Feb 06, 2011 9:09 pm
Make sure your wires are hooked up in the correct firing order... the only other thing I could think of would be timing. Try holding the gas pedal to the floor while cranking to suck in more air, preventing the plugs from fouling.
You could also pull the fuel pump fuse and crank it to see if it is indeed dumping too much fuel in. If this is the case, it will kick over and run for a second before dying.
The cylinders probably measured such low compression because the walls were washed out with fuel, causing a poor seal. Smell your oil. If it smells like gas, change it.
