1/4 mile times
boost_boy
NOTE:Please post your mods as well as the track info!
This thread is being restarted because the previous one was accidentally deleted. Keep in mind folks that this thread is more for reference and not up for discussion or arguements. If you feel the need to voice a concern relating to this topic, feel free to start a regular thread below. One warning, do not bring arguements to this thread or you will have wasted your valuable time because it will be deleted. If you post something that sounds rediculous, you will be emailed and validation of said claim will have to be produced or your post will be deleted "Point Blank". Keep it real and most importantly keep it clean.
My 1st time on the track was in April 2k2 with a stock CA18DET powered, 1990 b12 nissan sentra 4-dr. Mods included custom FMIC, MSD 50lb/hr injectors, a re-worked T25, a non-LSD gearbox, and SDS standalone engine management system.1st run was a 14.8@98mph on 13psi of boost on regular street tires, 35psi of air in all 4 tires (205/50-15 kumho tires on B14 SE-r 15in. rims). Just lauched the car too hard because I was excited and the thing went nowhere fast.2nd run was a [email protected]. This launch was a little better with less wheelspin, but still a weak launch nonetheless. This run was done on open-boost (yes, I pulled the hose off the wastegate actuator). It didn't make the car that much faster, but it did sound cool and caused my intake temperatures to shoot through the roof. Tire pressure this time was brought to 20psi.
In 2003, I replaced the previous sentra that was destroyed with another sedan. On Dec. 21, 2003, I ran a [email protected] with regular street tires. R/T=1.031, 60'=3.016, 330=7.059, 1/[email protected], 1000'=12.636.
In 2004, I took the new sentra (the other one got destroyed later in 2k2) with it's new T3/T04E stage III with a .48 backhousing, 205/50-15 BF goodrich drag radials on B14 SEL gunmetal rims, 7 y/o intrax/kyb suspension, much better tuning on SDS, MSD 72lb/hr injectors, MSD DIS-2 ignition box with 2 step launch control, better turbo manifold, hks 40mm wastegate, blitz and Greddy bovs, upgraded FMIC, NISMO fpr, and bliz dual sbc/turbo timer on board.
1st run got smoked by an S14 with RB25DET. R/T=1.287__60'=2.799__330'=6.928__1/[email protected]__1000'=12.414__1/[email protected]
2nd run got smoked by a 10 second Supra. R/T=981__60'=2.906__330'=7.207__1/[email protected]__1000'=12.735__1/[email protected]
3rd run against old neon with SRT4 motor in it boosting 25psi to my 18psi. R/T=.690__60'=2.578__330'=6.715__1/[email protected]__1000'=12.202__1/[email protected] (difference here was 2-step lauch, but still burned radials and went nowhere fast).
4th and final run against mazda6 and killed my clutch after 2nd gear. R/T=.348__60'=2.368__330'=6.312__1/[email protected]__1000'=12.979__1/[email protected]. This run started out to be my best effort for the day, but the clutch let loose after coming out of 2nd gear and I just let the car coast in neutral through the traps.
Have fun sharing your experiences, but remember to keep it real!
Dee
CA19DET
averaged 14.2-14.5's@100-105mph at 9psi
T3/T4E 50T .63 Stg3TRUST turbo manifoldXS ENG Intercooler (20x12x3 bar plate)TOMEI 260 ProCam KIT w/ TOMEI valve springsHaltech E6k, 3bar MapRC ENG 550cc Injectors w/ 255 WalbroAeromotive FPRHKS 1.6mm HeadgasketSPEC stage 4, OEM VLSD225 50 16 Kumho's
returning on the 26th more boost and slicks
nismoplsr
Where:Oct 2004 New England Dragway
Condtions:Cold (~40deg f) and night time.
Tires:Kumho Ecsta Supra 712 @ ~30 Psiwarmed up in the water box.
Time:14.5 @ 106 Mph 2.5s 60'
Mods:Haltech E6kGreddy Profec-B spec IIUnorthodox lightened underdrive crank PulleyLucas 550cc injectorsNismo AFPRZ32 TT fuel pumpGT28RS(.86 A/R hot) running 18psi of boostSpearco 26x6x3 intercooler2.5" exhaust
This was my first time ever on a track. I had trouble with the launches. I either bogged badly or just spun the tires threw the first 3 gears.
I was getting the hang of the track when my wastgate actuator arm fell off on the launch so i coasted the rest fo the track while i tryed to figure out what happened. Because i didnt have any spare e-clips and the car would have had to cool for a while before i could get behind the manifold the night was over for me. I had an awesome time thought and cant wait to go back this summer with some better tires and with my fully functioning studder box and anti lag.
USDM_OneVia
Car: Racing
Embarrassment time!
1992 SE Coupe
Stock T25Stock exhaust systemStock EVERYTHING except GReddy FMIC and 3in Downpipe
14.2@99mph
I can drive bishez!!!
Never ran it on the setup before I sold it....... oh well.
Joe
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
ok dee will post again
still a 1.8 liter CAthese best times achieved on radials, leaf springs (no ladder bars) full exhaust, full trim and still stock manual transmission.
60 footer 1.621/8th et 7.311/8th MPH 100
1/4 ET 11.51/4 speed 123 mph
engine specs can be found here
Modified by cortina-mk1 at 4:23 PM 5/19/2007
CA19DET
i just ran this weekend, 13.4@114mph was best.. running 18-20psi, on stock CA18DET with TOMEI valvetrain and T3/T04E 50t.. great runs, need slicks badly...
Nismo1182
Car: Z06
114 trap, spun a lot didnt ya hehe
Never ran my CA at the track but with the SR on stock sidemount, intake, 3" dp, 3" tp, 3" N1 catback and 10 psi, I did 14.0 @ 100 with a 2.2 60'
on 14 psi I did 13.5 @ 104 with a 2.0 60'
originalsin
well i havent gotten to the 1/4 yet, but i was just at the 1/8th for my 1st time
mods-3in downpipe, gutted cat, 3in apexi n1 catback-cone filter-ka24de TB-vlsd-205/50/15 yokohama es100's-centerforce dual friction clutch-sr smic-10psi
1st pass - very ****ty, my 1st time at a track ever lolr- 1.1660ft- 2.81/8th - 10.68@71mph
2nd pass - sumhow worser- .5960ft- 3.21/8th - 11.1@71mph
3rd pass - best oner- 1.0360ft- 2.51/8th - 10.33@72mph
i think with me learning to launch better i can make it into the high 9's
1SlowCA18DET
went to the 1/8 mile last night
60ft= 2.3330=6.11/8= 9.24@78mph
mods=evo 8 front mountz32tt fuel pumpka throttle bodyka maf11psioped diffsafcfull turbo back 3 inch exhauststock t25
what you guy think i'll get in the 1/4?
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
Not_a_sr wrote:well after a short day at the shop preping the car for test and tune we made the first track apperance ever with my car. showed up at 6pm left at 9pm got in 4 runs. the first run was the best of the day, and it just got slower as it went, but my trap speeds went up... i also did not drive i let my friend drive. i wanted to spectate what my car could do.. next time ill probably drive and see what i cant get out of it.
made these runs on mismatched used tires i bought down the street. full air pressure prob 35-50psi, on the first run coil overs set full stiff rear,full soft front. then half stiff in the rear and full soft in the front the rest of the runs.
i was car 132
second or third run
these were the fastest runs, the others were 13.6828 and 14.4878
nismoplsr
I just got back from the track tonight.
60' 2.4981/4 ET 14.569107.44 MPH
ozzie180ca
Car: 1990 180sx ca18det
My mate was running a CA in a datsun 120Y, s15 turbo and small fmic with toyo ra tyres and ran 12.3. Now is fitting a rb20 turbo.http://www.cruisingbrisbane.co...12115
Hillkill
Car: s12(killed), s13 hatch(rebuilding CA), s13 coupe(low & slow), e30 4door, FJZ80, ThunderChicken
Well a ca18det powered s12 can run 9.03 1/8th mile with some minor improvements (14psi, 255lph walbro, stock t25 turbo, open diff, CFDF clutch, 2 10in subs in the back, and on bridgestone potenzas) and still lost to some stripped civic.
1fast200
Car: too many to list
Wel,I just swapped a CA18DET for a customer in a 4 door, 1983 Toyota Starlet.Full weight, STOCK engine, Microtech MTX-8 ECU, T3/T4, Tial 38mm W/G, big FMIC, Injectors, twin RX-7 coilpacks @ approx 15lbs :
11.46 sec. @ 120 mph. with a slow 1.6+ sec. 60ft. due to big wheelstands.
1fast200
Well, an update from past weekend (5-28-06)
11.10 seconds @ 122 MPH, 60ft 1.53sec. Still BONE STOCK MOTOR!
Thanks,RYSO.
NeedCAforS13
Car: CA swapped S13 coupe
finally ran my ca18det at the track... first time EVER drag racing, so my 60 ft's kinda sucked.
on crappy drift tires dropped to 25psi. I spun all the way through first, and each time I shifted gears. I did however manage to beat the other s13 I went with 3 times in a row, and he's got an SR20
1st run:R/T: .70060ft: 2.4521/8: 9.771 @ 77.67mph1/4: 14.777 @ 98.89mph
2nd run: (best)R/T: .58060ft: 2.5051/8: 9.609 @ 79.61mph1/4: 14.53 @ 100.53mph
3rd run (I hit the rev limiter in 3rd and the car bogged HARD).R/T: .51660ft: 2.4731/8: 9.538 @ 79.76mph1/4: 14.544 @ 98.18mph
mods are intake, exhaust, downpipe, fmic, s14 gt28, 10psi. I have an safc as well, but I haven't done any tuning with it. I have a maxima maf and 550cc injectors, once I install I'll turn it up to 14psi and get some good tires and hopefully go deep into the 13's. I think with trap speed just over 100mph, high 13s are within reach right now even.
edit for some pics: mine is the s13 in front, the other is my friend's car with an SR20.
originalsin
went 9.6@73 in the 1/8 tonite, 60ft was 2.23, was pretty happy considering my times up above, all i did since then was put some bigger tires on and do a hg and studs
shogun!
Car: Nissan 200SX S13
So far he best time we have here in Sweden, with ca18det in an S13:11,47 191 km/h60 feet 1,59
Not me...I wish...
http://web.200sx.nu/MetaForum/...0&S=1
On my way towards better performance...
http://www.garaget.org/?car=16972
teambuiltnissan
Car: nissan 2 dr
I finally had time to do shake down pass. this pass was made with 26psi boost. missed 2nd gear and spinning pretty bad on 1st
r/t 1.17560 1.789330 5.0421/8 7.576mph 103.921000 9.6731/4 11.24mph 134.84
I should be able to run again on end of this month if I get lucky enough....
teambuiltnissan
Car: nissan 2 dr
pic
teambuiltnissan
Car: nissan 2 dr
2nd gear burn out
Ca_Silvia
Here is my bone stock CA 1/4 mile times. First the car was setup for autocross that night and it was my first time at a track. Now that the excuses are out of the way here are the numbers:
R/T .42460' 2.3330 6.061/8 10.11000' 13.21/4 15.77MPH 89.4
This was my fastest run of the night i did however muster a .232 R/T once and a 90.9 MPH on one run also. So i feel confident that the car can do low 15's
ca18hatch
Car: 1992 240sx hatch w/ca18 swap
Second time at the track, running stock t25 and stock everything except 3" exhaust and greddy boost controller at 12 psi, vlsd.60ft-- 2.01/8 mile-- 9.1@79 mphWe dont have a quarter mile track nearby, thus only have 1/8 mile times.
WaKoS13
Car: S13 Silvia
My S13 has ca18, auto trans, custom intercooler, t25g twin dump pipe, 3" exhaust, rising rate reg, walbro fuel pump, rb20 AFM, and a pod filter 14psi boost done:1/8 mile:r/t 0.43760 f/t 2.1 secet 8.637 secmph 82
smoked a manual r33 running the same boost all night
240sxbobbis
Car: owned a ca18det s13 two of them, jeep wrangler, suzuki gsxr600, 86 mazda rx7, and a y33.
well i went to the 1/4 mile track in Crofton Maryland on Friday known as capital race way and did bad well honestly it was my first time dragging my car on a track before so the experience was totally new to me i ran an 15.573 at 88.78 miles per hour
Phyrx
Car: 2001 Audi TT Quattro
Ran on 4-6-07 @ Montgomery Motorsports Park in Alabama
14.1 @ 98 mph
Stock internal CA18DET RWDStock slipping clutchNO LSD290k suspension100lbs of parts in the trunkFull weight 90 coupe
Buddy Club Spec II exhaustWeird turbo... (80 a/r front and back but looks like a stock CA turbo)Stock boostApex Hybrid GT FMICCusco Cold PipeHKS SSQV Blow Off ValveSSAC Downpipe + Test Pipe
Same night I ran dead even with my best friends SR20 @ 14+ psi from a 50 kick and he ran a 13.7@104 at the track the same night
I should def. have high 13's with a better clutch, LSD, and suspension.. on stock boost!
dvd
Just got back from the track. It was my first time.
Car:69 datsun 5104.11 diff ratio subaru lsdgt2510 @ 10-11psisohc ka maf running as blowthrough
Car's been running rich constantly around 10:1 everytime, no matter how much I change the boost. I have a walbro inline 255lph pump and a nismo afpr.
Car is too low in the rear so there's a lot of camber. Anyways here is the best time i got.
r/t 1.16960' 2.4871/4 14.358 @ 99.74 mph
Pretty sad considering phyrx got a better time and he has a stock turbo with stock boost. Ha
Phyrx
The turbo I had wasnt stock.. looked more along the lines of an SR turbo minus the flanged inlet... weird.
Nice times though
ser20det
Car: Silvia K's 88
Well ! First time at track forever !
Silvia k's jdm 1988 ca18det Bone stock (full loaded...it'S a k'S anyway... a/c, P/s, P/w, Abs, etc ... Street tire yokohama evs es100
Best runE.T.: 15.351Réact: .360Mph: 90.341
Best mph of the night: 90.625Best Reaction time : .206
I was very happy with my first time at track with my stock ca18det car and fully loaded!
Modified by ser20det at 8:22 AM 6/25/2007
shelnut
Car: 4D B13 Boosted
14.5 at 99 with restrictive 3 inch ehaust 3 inch dp crappy intercooler hks f-con spec stage 1 clutch r32 rear end and sr turbo on about 9psi
hoping to get into 13s today on about 11psi straight through 3 inch ehaust big hidin frout mount and a little 110 octane
Modified by shelnut at 10:23 AM 7/17/2007
