I'm running the ka24de out of a 95 240sx in my 510. the car weighs about 2300 pounds. it has no cat, a magnaflow and an intake. I ran a bunch of 15.6s at PIR last night, which I think is pretty slow. it was my first time out, but by the end of the night I was launching and shifting at what seemed to be the optimum points, but I just couldn't break 15.6the only reason I'm posting this is because AunVoh posted a 15.4 on a pretty much stock 95 SE, which I think also has power-sappers like power brakes and steering, and should weigh about 2700lbs at least.I figure there are two possibilities:a) I suck. I might give in to this if nothing else turns out.b) My engine is having some trouble. The ECU doesn't receive any of the speed sensors or other things my car doesn't use, and I'm wondering if maybe it's in some sort of run-rich timing-retard mode.
I've seen how to check the ECU for error codes, but I've never seen the red LED on any side of my ECU, and so I've never gotten very far.
but anywho, 15.6 @ 86.57. I beat a couple of WRX's
(barely)
