94VG30DE »
https://forums.nicoclub.com/94vg30de-u30019.html
Sun Jul 17, 2005 2:22 pm
Ok folks, my little brother just acquired a 90 Nissan 240SX SE with a 5-speed transmission. There are 86000 miles on the ODO, and other than rust the engine runs great. However, I am having all kinds of problems when shifting into 2nd gear. If I try to shift slowly, it just sits and grinds as if I don't have the clutch in. When downshifting into 2nd gear, it does the same grinding motion. If I just throw it into gear without giving it time to complain or grind, it hits with a resounding "clunk" sound. I know how to shift, and I have tried everything I can think of to get around the problem. I have tried double-clutching, I have tried rev-matching (which should completely bypass the syncromesh if I am not mistaken), and i have tried shifting as smoothly as humanly possible. This problem does not occur, however, if I shift into 2nd gear at what appears to be below 25 miles per hour. The problem does not seem to be tied to RPMs, b/c I have tried the maneuver at various RPM levels.
Also, the shift lever has a considerable amount of side-to-side play even when in gear. I know a little play is standard, but this knob moves about 3 inches side to side when in gear. I dont believe it is a serious problem, but it is incredibly disconcerting when cruising or sitting and the knob is able to move that much.
Thanks for any help you can give!
chris
