LMG_35C »
https://forums.nicoclub.com/lmg-35c-u29152.html
Thu Aug 31, 2006 12:05 pm
Check out Motordyne web site for specifics but the options are
1. Spacer - Tony now includes aramid gasket for insert between upper and lower plenum2. IsoThermal Kit - includes aramid gasket for lower plenum to intake manifold, and a cooloant control valve to stop coolant from heating plenum and Throttle body. CCV can be left in off position if you never expect to see freezing temperatures. 3. Copper Thermal upgrade is inserted beweetn throttle body and plenum. It allows coolant to flow and only heat TB, not the plenum. This eliminates need for the manual coolant control valve, and is useful if you expect to see freezing weather
Let mw know if you have questions, or you can call Tony at Motordyne.
