hashiriya13 »
https://forums.nicoclub.com/hashiriya13-u4580.html
Fri Aug 22, 2003 4:28 pm
Engine mangement. I would say get that first and because once you start getting into the other things you will need it anyway. Get what you can out of the stock setup first and go from there. I boost 7 on a regular basis which is stock and go to 10-12 just to feel the kick in the a$$. I started with the FMIC, Greddy IM and 3" turbo back exhaust. Had a couple issues. It was to much I think for the stock computer with no management with our low fuel grade. I know have sard 550 injectors, Power FC, 300z mafs and a few more pieces but not yet installed. Waiting on my new turbo. Cant say much now on the turbo, working with Mckinney Motor sports on that. They are getting one speced out for the RB25 as a replacment for the stock. Oh and the first one may be going on my car. then they should offer it as well after we see how it works out. The expected HP numbers are pretty high if it all works out. But that is a secret. So anyway the stock turbo will be one of the show stoppers for reliable high boost so you could start there as well. Another thing you may consider is a fuel regulator. I am using the HKS An fitting adapter with the aeromotive regulator. That with a SAFC may work for you for a while Vice injectors that you wont really need for a while. Well those are just some of my Ideas. You choose what you think is best for what you want. You will be very happy once everything gets worked out and you drive her for the first time even in stock form.
