I would also stay away from home brewing oils.
Even tho the exact example, you mentioned, it wouldnt be a problem as the additive chemistry is the same ( same oil formulation) and the exact vicosities you mentioned happen to be VII free in Mobil1 10w-30 and 15w-50.
Its the VII's and their unpredicatbility in home brews that make for problems with mixing sometimes, even if in same brand and line of oil.
In this particular example no problem:Mobil1 10w-30 is VII free and 15w-50 also,or nearly so.
I dont think a 15w-50 would be too thick for a turbo run in SoCal in summer.My SR runs on M1 15w-50 right now and I am in KY.The Australians whose temps approximate SoCal summers run even thicker sometimes ( they sell 25w-70 over there and a couple of 60 weights)
In summer Mobil1 15w-50 or another full syn 50 weight is likely a good call.In winter the Mobil1 0w-40 will be a good choice IMO.
Fred..
