loystock wrote:
1)But I have Japanese cars which have different specifications and whose reliability are way better than European cars.
2)Per Infiniti FSM, I must be using 5W-30 (or 10W-30 at temp above 0F). The API grade is SG/SH for the older cars and SJ/SL for the newer cars.
3)So for my cars, the recommended viscosity at operating temp is @ 10cSt with 30 weight and not @ 14cSt for the 40 weight. If I use 40 weight, the oil is thicker than recommended and my oil pump load will be higher. Based on viscosity alone, I have optimum lubrication using 30 weight oil. Based on the above and what I know about oils, I have no reason to use 40 weight oil in my Infinitis.
I see you did your home work thats good I have a little more time right now to typeso here is my humble input:
1) Internal combustion engines are internal combusion engines no matter who makes them. then only thing that really affects your choice of viscosity is bearing clearances of which there are little differnces nowadays between the 2.
2) The Infiniti literature actuare also allows the use of 10w-40 in summer. For some of the newer cars it may not ( i havent checked) but keep in mind that beaing clearances on the VK45de are not tighter than on the VH45de (if anyhting they might be looser). Also the VH45de has very tight rings, tighter than the VK45de yet still allowed 10w-40 in summer.
3) It makes sense for you to aim for oil choice based on operating viscosity for your cars, which is basic physical chemistry.
But here is the kicker:Ambient temps during a USA summer are MUCH higher than in a european or japanese summer ( Especially in US south but even in the north you see 90 and even 100 F regularily which you dont in Europe or Japan except by rare exception). This mean oil temps will be higher. This will thin out your oil a bit,... enough IMO to make 40 weight oils the better choice in USA summers for VH45de and VK45de powered cars.
Fred...
PS: the SAE has viscosity dinwos ( as posted earlier) to what constitues a given viscosity in steps 30, 40 etc but for clarity's sake lets assume they published it not in classes but in greater granularity:
So its true the 0w-40 (which is really more like a 0w-38) tends to shear down after 2000-4000 miles a bit to somethng more like a 0w-34.But thats still better IMO than the xw-30 formulations from MOBIL which tend to run more like a xw-28., if there was such a thing.On the other end of the spec is the 0w-30 Syntec which starts out as a 0w-34 or so and tends to stay there for quite afew miles.
Modified by PalmerWMD at 11:52 AM 12/13/2009
