Is they sayin' that us Americans speak worser than the Canadians? I reckun I speak as good or gooder!teammcw wrote:I believe someone mentioned the reason it's not enabled is because of the delay between the longer phrasing... But not sure...
Anyway, I was a little pissed seeing the larger voice command set for the Canadians.... What's up with that?!
How do you get into the software diag mode?teammcw wrote:I finally had the chance to get into the software diagnostics on my vehicle - it was fun driving to work with the rear view camera enabled the whole way. Pretty wild.
Wow, nice work, we all appreciate the info!brainguyus wrote:I just called Nissan Corporate (1-800-647-7261) and was forwarded directly to the Nav Software manufacturer.
The person I spoke with said it's not possible to switch to the Canadian voice commands. To do so would require changing out the nav hardware as well as a full software reload. Strange?....I guess they store much of this in firmware.
I forgot to ask him why the US Nissans have a stripped down command set.
Regarding hardware; The only thing I can think of is that the dealer mentioned that Canadian cars have a different speedometer. I don't know why.....I would guess that it should only be a cosmetic difference. If they do have a different speedo, how tightly it would be integrated into the software is anyone's guess. A larger hard drive is definitely a possibilty.teammcw wrote:I wonder what could be different (hardware) that would add/remove voice commands. Seems to me that it would be software controlled. From what I remember, all of the voice data is loaded on the hard drive...
Maybe they just say that to prevent people from trying to clone/copy a Canadian drive... Or, maybe, because of the command base, the Canadian drives are larger? I think we have 30GB drives in the U.S. cars... 10GB free for Music Box, leaving 20GB for maps and voice...
Can any Canadian confirm the hard drive size in their vehicle? Or, if someone is brave enough, take an image of it and check the partitions and sizes? I would take the drive out of my vehicle, but am still waiting to acquire the service manual...
It's in PDF format. Check my profile for email and drop me a note.teammcw wrote:Did you get a PDF version or physical? If PDF, could you post up the sections on disassembling the dash/console area to get the electronics out? I really still want to check out the contents of the drive.
This is going to be my next trick. I'm going to call corporate next week and see what they say. I'll probably get some canned response but let's see what happens.teammcw wrote: What would happen if you tell the dealer that you are moving to Canada, where DRL is required in every vehicle
I'm checking out other packages that may be able to do this using only a laptop. I want to take a closer look at 'OBD II' and something called 'Conzult'. I think both of these support the CAN protocol. There are several others as well.teammcw wrote: I was checking out the CONSULT III commands available (wish I could get my hands on one unit to test - $6k is out of my price range)
That definately bites!...explains why I couldn't locate the dvd drive. That's pretty tricky marketing, calling it a DVD 'based' Nav System.teammcw wrote:And surprisingly, you use CONSULT III to load the map data onto the hard drive. Does that mean we will have to pay the dealers when a map update is available, or would that mean no update will ever make it to our car?........We spend $190 to order the update, which is simply a license number which we provide to the dealer.... Dealers spend a one time fee of around $350 per CONSULT-III machine (or maybe for all) to get the hardware and updated maps.... In any case, the map publishers are definitely making money off of this deal.
....Save the trouble and just go to Canada for a new Murano!teammcw wrote:If I win the Lotto or something, I'll probably order one
Yes, I was going to post this and the results of my Canadian "fishing" trip at the same time.teammcw wrote:Hey Jim:
Have you heard back from AutoEnginuity yet?
