I reached out to the guys @ fes auto (
[email protected]) and it sounds like they are willing to make a unit for the Rogue! Below was the reply:
Quote »Hi Chris, we're game to do a module for this. But it will take some work on both of our sides. Here's what you'd have to do:
· Find out about the wiring of your car. Since the window controls are probably not in a center stack, it's possible that there won't be an easy place to get to both window controls. This isn't a big deal but it may be easier to put two modules in (one for each side) than to run wiring from the doors to a central location. If all the switches come to a master control at the driver side door, one module can probably do it. We'd also need access to Vbatt and ground to power the circuit.
· Find out about the signals with the switch control. We'd need to know how the voltages go. For example. The Mini uses a body control module to run the motors. The switches provide a contact to ground that the body control module senses. Our circuit mimmicks this contact to ground (logical low, really) and acts like someone holding down the button for a fixed amount of time.
· Be willing to do the install into your car, documenting the install so that we can make an installation procedure for whatever we create.
· We'd charge 2x the auto-up cost, and won't really make any money on it considering the time it will take to make, but that's what customer service is all about! Who knows, if it's a hit with other Nissan owners, it might actually work out well!
So, if you're really serious about it, we'll be happy to help!
Matt & Guenter[/quote]Double the MINI unit would be about $100, still a great deal IMHO.
If your interested in being a BETA tester along with me reach out to the guys @ fes-auto and let them know. I expect the higher the demand, the faster they will respond.
Also - I could use some assistance gathering the details they need. If anyone knows where to get this info, please add the content (or links to it) on this thread...
