09 Nav system in a 07 M35
6stringnovice
Car: 2007 Infiniti M35
I recently purchased the HDD Nav system for the '08-'09 model M35. I own a '07 Infiniti M35. I've installed the new system and found that the Displays is scrambled whenever I turn on the system. 4 Questions:
*Is there anyone out there who has tried this?
*Any ideas on the Cause/Fix?
*Will installing the Touchscreen Display fix this problem? if so...
*What is the Name and Model # for the '09 Infiniti M35 Touchscreen Display?
Thanks in advance...
300ZXttZMAN
Welcome to Nico!
:facepalm:
Well the first thing is that why on earth would you buy one for an 08-09 model?? These units are all computer controlled you cant just say "hmm they look the same so it should work :nono:"
Second the cause/fix will be to get the correct one. Along with the computer that controls it.
:luck:
:bigthumb:
