BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Fri Jan 08, 2010 7:03 am
If you wanted to convert your odometer to miles (because I don't believe the Murano will switch from one to the other electronically), you'll have to swap the entire cluster to a Canadian model. But first, I would ask the dealer maybe? If you're lucky, there might be a jumper or key combination that can switch it from one unit of measurement to the other.
The reason your post is getting few replies is likely because this is not a very common problem... One other problem you'll have is I believe you Canucks require daytime running lights, while yankee vehicles do not have this feature.
