coastal6.0 wrote:it's not so much that the front door spks aren't doing their job correctly, it's the fact that they are crossed over really low in the factory bose amp.it's all in the name of imaging, so the sound doesn't get pulled down to your feet. that's why you hear more sound information coming from the back doors than the front. front seat passeners get great imaging and rear seats get good stereo sound. bose did great research in finding correct locations on the high/mid range spks to get the best possible soundstage. well, at least for most people. all equalization and processing takes place in the bose amp. you could probably get away with swapping outputs on the factory amp between front and rear doors to get a broader frequency range in the front doors, but if you turn on the processing features in the radio( some bose radios give the option of left front, right front, all seats, kind of like surround sound settings) somethings might sound funny. if you leave everthing set to normal/centered except bass/mid/treble you probably won't have any issues. good luck and keep us posted.
I think you are quite right about imaging. Today, I pretty much set everything to default and the soundstage on a few FM stations and a CD I sampled was quite good. The tonal balance though is somewhat skewed upward. I used to be big time into high end home audio equipment and attend live concerts frequently (mostly classical or smaller ensemble....acoustic in any case) and I think the spectral balance isn't right. Problem is, that when the error occurs with pushing the upper frequencies, the sound can be pleasing for a short time but fatiguing. That's what the Murano is doing to me. My older ears probably doesn't help matters though, LOL.
Modified by spastic at 12:28 PM 10/12/2008
