gratefuldiver »
https://forums.nicoclub.com/gratefuldiver-u239918.html
Fri Aug 08, 2014 5:53 am
My 09 Murano locks started acting crazy yesterday. The remote unlock doesn't work so you have to use the key to get in. Once in you can hear the lock actuator constantly activating (unlock-lock-unlock-lock) It doesn't stop even after the car is parked and off.
At first I thought it was my wife's remote so I removed the battery and we left in the car with mine but it does the same thing. The only way I could get it to stop was remove the fuse for the BCM. Im thinking its a switch shorted in the drivers door switch assembly but wanted to ask before I tear into it. Im really hopping its not a problem with the BCM as I see it monitors the feed back from everything and sees when the switch is high or low. I tried to de activate the auto lock control per the manual but it doesn't work, the problem persist. I also noticed that when I tried to arm the alarm and lock the doors the horn didn't honk as if some switch wasn't satisfied (This was before I pulled the fuse)
Removing the fuse kind of sucks because I loss my blinkers and window control but I also don't want to burn up the actuators for the locks. That and trying to get the kids to lock there door when they get out is imposable LOL
