fat3oy »
https://forums.nicoclub.com/fat3oy-u190004.html
Mon Mar 30, 2015 2:22 am
lol - yeah two belts - and what mechanic would recommend belt dressing - awful stuff, saturates and gums up the belt...
if it is belt squeal - loud annoying, etc, worse under acceleration, worse turning - new belts, tighten to spec... ALSO to triple check, tighten your tensioner, if the sound gets worse, one of your pulleys is acting up. Better? yah need a new belt...
the moisture he's talking about is between the ribs of the ribbed pulleys, causing uneven contact, and belt slip, causing whine (that when warmed up, goes away) much worse when a belt is old, stretched, dry etc.
