'09 M35 2000 RPM idle when started cold normal?
m4m
Car: 2009 M35S
Just curious, what's your M idling at right after you crank it cold?
When I crank mine it starts off idling at like 2000 RPM which seems kinda high and then as it warms up it slowly drops down to around 1000 - 800 RPM about a minute after it's cranked.
Just curious if everyone else idles this high (2000 RPM) when cold.
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
I have an 07 but not sure if it idles cold that Hi I'll post back later
EniGmA1987
Car: '06 Infiniti M35 Sport
Mine does that sometimes, depends on the day. Doesnt do it if you are driving though, just parked and idle.
themacs
Car: 2009 M 35, C 6 Corvette vert
I have the '09 M35 . Just started it up 1st time today. It is 64 degrees out and the idle was 1700 rmp. Then it drops down of course.
Hope that helps.
Scott
m4m
Car: 2009 M35S
Thanks Scott!
So 2000 rmp on very cold morning (it was about 37 degrees) sounds about right.
Since your M has the same engine and 7spd trans as mine, do you feel an excessive engine braking after lifting off the accelerator pedal at about 30mph and again about 20mph and a 200 - 300 RPM increase?
