09 coupe won't start need help (video)
All things Altima Coupe.
importedk
Car: 2009 Altima coupe
I have an 09 Altima coupe.
I am currently replacing the door with a used one and will be painting it later. However suddenly it won't start any more.
I have uploaded a video to better illustrate what is going on here:
http://www.youtube.com/watch?v=0mrRrYa9DVE
As you can see the following is working:
Brake switch (I connected the lights and brake lights are flashing)
What is happening:
Lights work and battery is charged, car only has 19k miles!
I get into the car, press the gas pedal and push the button once and it goes to acc mode, after that I press it again to on mode, after I press to start the car it dies.
What is not connected:
2 air bags are not connected
Driver seat belts are not connected
And door is a new door that I am installing because the old one is gone.
Would any of the above make that car go into a safety mode and not start?
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
importedk wrote:I get into the car, press the gas pedal and push the button once and it goes to acc mode, after that I press it again to on mode, after I press to start the car it dies.
Oh boy. When you get into the car, you are supposed to push the BRAKE pedal and push the start button. All you are doing by pushing the gas and the start button is cycling through ACC, on, and off.
EDIT: I didnt even watch the video before my first post, apologies. If you are indeed pushing the brake and not the gas, then you have a problem. Looks like a salvage buy? Are you sure it has a starter?
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
importedk wrote: I get into the car, press the gas pedal and push the button once and it goes to acc mode, after that I press it again to on mode, after I press to start the car it dies.
lolllllllll
