'09 and '10 EX35's .. Hatch opening?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
kamiguy
Car: 2008 EX Scarlet silver wheat interior.. all options
I have an '08 and even after the hatch struts were replaced, cold weather stops the hatch from opening more than halfway, and must be manually lifted to completely open. Are newer owners experiencing the same thing?
jamesstock
Car: 2010 Liquid Platinum/Stone Journey
Diamond Cut IR Tint
My '10 hasn't done it 'yet' knock on wood!
But could it be the 'dirt' that got built up overtime at the struts hence affecting the 'lift'?
kamiguy
No, not dirt... it was fine all summer and fall, then when the cold snap hit it fails to open all the way. There was an older post about this in the '08 days and just checking now to see if the newer models are trouble-free!
Richard Y
Car: 2008 EX
2010 Murano
HI. I have a 2008 EX. I have had my struts replaced once (full warranty, no cost to me), and frankly, before the end of my 3 year bumber to bumper warranty, I may ask for them to be replaced again. It seems the struts are simply not strong enough for the weight of the hatch. Good luck!
Jason Tucker
Car: 2010 EX35 AWD Journey Dark Currant/Chestnut
kamiguy wrote:I have an '08 and even after the hatch struts were replaced, cold weather stops the hatch from opening more than halfway, and must be manually lifted to completely open. Are newer owners experiencing the same thing?
Kamiguy...don't know where you live but I experience the slow moving hatch when it gets cold...like here in WI. Must be some fluid they use in the struts that gets thicker with a drop in temp...it's fine in the summer. Anyway thats what it feels like to me when opening the hatch...yup it does suck...but love my EX!
kamiguy
Western Canada.. where we are getting January weather in November! So it seems Infiniti hasn't changed struts.. sad when my wife's lowly Pontiac Vibe hatch opens fine in all temperatures!
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Maybe the hinges need some wd-40 or other penetrating oil. Spray it in there and open and close the door a few times to work it in.
KJ911TT
Car: 2004 Porsche 911 Turbo Cabriolet
2008 Infiniti EX35
No, it happened to my EX and I had the struts replaced and when the cold weather hit this year, the problem came back.
The gas in the struts is under lower pressure in the cold which causes it to lose it's "lift".
This is not as obvious on brand new struts, but the EX struts lose their strength fast.
Their quality is pretty crap IMO. I had the same problem on my FX45. Seems like Nissan/Infiniti use a crappy supplier.
- KJ
PolarDog
Car: EX35
My hatch is actually falling closed. It will not remain open. Been replaced once already. Been told not to lubricate. Much pressure required to pull open at all.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
:gotme:
I've only seen a few issues on the old QXs, but those had very heavy doors and an automated motor system in addition to anti pinch and closure monitor system. The EX uses a much smaller,lighter, and composite hatch but struts can get weak. With nothing but a partial closure motor weighing down or complicating the door it should make sense that a set of struts should fix this.
I know as a tech I have replaced several sets of struts in several vehicles for all types of reasons and I have not seen many return after proper replacement. They can indeed fail for several different reasons but the results are the same. However I find repeated failure interesting.
Has anyone called CA about this yet?
jirbas
Car: Infiniti ex35 2008
My '08 has the same problem. It seems that temperature afects the operation. I have a MPV van and never had a problem. I've tried lubricating the shaft, but no luck. It is hard to lift the door.
btw what is 'CA'?
kamiguy
I am thinking Consumer Affairs..
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
