09 altima coupe transmission noise startup cold
All things Altima Coupe.
chiapetchua01
Car: 09 2.5s a/c cvt
hey guys
trying to figure out whats the problem. My 09 altima coupe has funny tranmission noises when I startup the car in the morning or after quite a few hours off. its sort of a grnding/chatter noise 2 times (for maybe 3 seconds) and 1 longer one (5 seconds) and it goes away. Happens without fail on startup after the night/ or when off for hours.
Any help would be great
Aaron
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
you sure its transmission noise?
are you sure its not the typical low oil level timing chain chatter that almost all nissan engines experience?
chiapetchua01
hmm i never considered that
always thought it was the transmission
how would i fix that?
the noise scares the hell out of me
ImStricken06
2016 Kia Sorento
chiapetchua01 wrote:hmm i never considered that
CHECK YOUR OIL LEVELS! thats really important in all nissan engines, as consumption is a common thing. i dont wanna say "problem" but its certainly a "thing" in nissan cars. plus with higher miles, its going to eat more due to piston ring wear. so you have to also keep that in mind, and also think about maybe you need your timing chain adjusters replaced. they are regulated by oil pressure - but the guides are plastic.
does it start like this?
[youtube]http://www.youtube.com/watch?v=8NY0TBjAtqA[/youtube]
the only thing in your transmission that moves/works when your in P is the fluid pump. i doubt thats the problem.
mmkeller
Car: 2017 Maxima SR
2009 Murano SL
Could be a loose heat shield, once warm they tend to stop chattering.
chiapetchua01
thanks im but i believe mines is a different sound.
How would I check the heat shield mm?
chiapetchua01
any other thoughts?
could it be time for transmission fluid change?
i'm taking my coupe on a trip to socal soon so I really want to get this fixed
Firedancer
Car: 2008 Nissan Altima Coupe 2.5
If it's the heat shield there isn't a whole lot you can do about it. Pretty common in our vehicles. Mine does it as well.
ImStricken06
2016 Kia Sorento
Firedancer wrote:If it's the heat shield there isn't a whole lot you can do about it. Pretty common in our vehicles. Mine does it as well.
bang it down with a mallet. that will stop the ringing.
chiapetchua01
by heat shield, you mean for the intake i'm assuming?
ImStricken06
2016 Kia Sorento
intake? dude we are talking about EXHAUST heat shields lol
chiapetchua01
LOL sorry im just a scrub back here.
really appreciate all the help
been busy working on my miata and grad school but i'll try to be more active around here again.
i'll double check later on
thanks!
