08 Spec V fog light
ssjnimma
Car: 2007 Nissan Sentra SE-R Spec V (Black)
Hey guys, so i was getting in my car today for work, and noticed that my fog light looked really shinny.... odd cuz my car is so dirty from the snow and **** here.... so i got close and looked... well i guess my fog light shattered some how?? my question is, where should i look to get a new one??? and how hard would it be to replace??? should i look into just going back to the dealer???
let me know! thanks guys
Lazybeef
Car: 2006 Nissan Sentra SER Spec-V
Same thing happened to mine(I have no idea how). You have to take it to the dealer and get the whole lamp assembly replaced on the broken side. They might try to sell you a complete set with 2 lamps but it is possible to get only one. With installation it will cost around $125 (I know, A bad deal but the glass can't be purchased without the lamp assembly).
jbarbaresi
Car: 2007 Nissan Sentra SE-R SPEC V
if your warranty won't cover it, which i'm guessing it won't, and you have to buy new fog lights you might as well get yourself a nice set of HIDs or something. don't spend $100+ just cause that's what the dealer is going to charge you for a $30 bulb.
ssjnimma
yea i was looking online for some lights..... i did find like one thing that could possibly work on ebay?? not sure if it would or not, but what would you recomend? cuz i really didnt find much.
thanks
ssjnimma
i found these listed on ebay:
http://cgi.ebay.com/ebaymotors...ZWDVW
do you think something like this would work to replace my factory ones? and is it pretty easy to install? also i noticed it comes with a switch? is there anyway i would be able to just use my original switch like when i turn the headlights on??
02SPECtacularV
Car: 2002 nissan sentra se-r spec v
can that new se-r spec v engine fit in an 2002 se-r spec v?
nametakennow
Car: '06 MINI Cooper S
Same engine externally, so it should drop right in, though you'd probably need an 07+ engine wiring harness and ECU.
Lazybeef
Waste of money. The only difference between the 02 and the 07 is the Transmission. The new one is CVT and has a much taller redline which gives it the extra power. It would be cheaper to either A) spend lots of money doing a good job of turbo-ing your car or B) have your ECU reprogramed by a computer guru.
