08 Sentra S - I want some 18's
whispanic
Car: 2008 Sentra S CVT - 2007-2010
2009 Cube SL CVT - 2010-
2009 Versa - Tha work car
I dont like the gap between the wheel and fender.
I was thinking 18's would work well so I dont need to lower it.
Im looking for low cost 4 lugs wheels.
Anything I need to know? 17's better?
Appreciate anything you got...
gotak
Car: 2007 Sentra SE-R
17 inch tires are cheaper. So you should consider that. 18s would require very low profile tires which makes the ride more bumpy and also cost a lot. Larger rims at times weight more then smaller ones and might make the car handle, accelerate and brake different.
Personally for me I think if you got drums in that back large rims just shows those off. And that's not pretty IMHO.
nametakennow
Car: '06 MINI Cooper S
17's would be a better idea.
Here's the issue, though.
When you put new wheels and tires on you keep the same overall diameter (or very close) in order to keep the speedo/odo calibrated. Thus, you're not going to reduce the gap much if at all because the new wheel/tire shouldn't be taller than the old one.
You're going to have to lower it if you want to get rid of the gap. Eibach Pro-Kit springs will fit on stock struts without blowing them and give it a pretty decent stance. There's a thread on this on the first page of Sentra General.
