'08 Sentra leaking windshield washer tank
dedlock
Car: 2008 Sentra 2.0S
I saw this issue mentioned somewhere else, curious whether any of the members here had the same washer tank problem I had........
Shortly after taking delivery I noticed a leaking washer tank. After filling, it would be empty within a few hours. Leak occured whether washers were operated or not.
Took it to the dealer and had it repaired. Here is their comment on the problem:"Packing checked. Found washer pump packing leaking. Adjusted and added a rubber washer and filled. Rechecked. No longer leaking" I believe they're talking about the point where the supply tube exits the bottom of tank.So far the repair seems to be holding. Dealer advised that if leak reappeared they would replace washer fluid tank. Maybe assembly plant got a bad batch of washers.
