MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon Jul 06, 2009 2:13 am
Engine and transmission are identical. There may, however, have been some minor changes to electronics in the intervening years. In those cases, you'll probably be fine if you just use the electronics from your Titan. You'll need to stick with the ECU from your Titan anyway, as it's set up for the specific options your Titan is equipped with.
For reference, in case it's helpful, the engine is VK56DE and transmission model number is RE5R05A.
Does the QX have front-end damage? I've always thought if I had a Titan, I'd put a QX56 front end on it. I love the QX's fascia.
