08 Maxima won't start after battery change
VLLindsay
My 08 Maxima will not start after I changed the battery terminals. The battery is good, but the car just starts blinking consol lights and overhead lights. Doors want lock from door controls. If I lock the car with the remote the overhead lights won't go out. Help?? I've waited hours for something to reset. Checked the battery - it is good. Tryed jumping it off. Nothing. Its Staurday and Nissan doen't open until Monday. Help!
93coupe
Car: crap
You literally only changed the battery, didn't touch anything else?
VLLindsay
As far as I know. If something else was touched it was on accident
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Why did you change the battery terminals? Do you still have the original ones? Maybe you could try putting them back and see if that's the problem.
VLLindsay
The old ones were corroded. I had cleaned them about of month ago, but they corroded again, so I changed them out and applied that stuff to keep them from corroding again. The old one feel apart when I took it off.
Otto.
Try checking your alternator and your fuses.
ADDirishboy
Car: 2008 Nissan Titan Pro4x
The battery terminals fell apart already on an 08?
This is why I only use dry cell batteries.
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
I think it might have something to do with the security system/immobilizer key......
Dattebayo
Did you make sure all connections were re-attatched as they used to be? There are a few smaller wires that you may have missed...
Also, the anti-corrosion stuff you spread on the terminals, did you put any of it on the inside of the connectors? It's only supposed to go on the outside AFTER you attach the new connectors BTW. Di-electric grease is non-conductive!!
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Did you hook up the battery the right way....positive to positive, negative to negative? It might be a silly question, but I've seen it happen numerous times.
