08 ex35 ignition coil
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Kratos12a
Car: 2008 Infiniti EX35 journey
on the coil pack, is the bolt that has it in place also serve as a ground?
Good question. Not likely, but a peek at the FSM may help (infinitiservicemanual.com)
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
I'd bet that like most ECM controlled cars now the ECM grounds the coil to work it and no ground used locally at coil itself.........
Kratos12a
ok thank you. i had a shop replace the coils going bad, my warranty only covers what the code says, so they are doing 1 every Saturday when they go bad.so i bought myself 3 to install myself and started to wrench on the car when i see coil number 1 bolt is clean snapped off below the coil pack and turns freely. thanks for the info going back to the shop to make them tap out the 10mm screw that holds on the coil.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
