zakmartin »
https://forums.nicoclub.com/zakmartin-u136442.html
Fri Oct 28, 2011 11:34 am
For anyone else experiencing this: you might want to try adding distilled water to the fill line in the battery since the battery in the Rogue is not maintenance-free. Just yank off the caps over the cells and fill 'em up. Also, clean your terminals and connectors (get a terminal cleaner at the auto parts store, they're only 3 bucks). Add some anti-corrosion compound or WD-40 to the terminals and you're good. Hopefully, that will solve the problem, but as mentioned above, it could be other things.
If you have a multimeter, check the voltage on the battery when the car's off. It should read 12.4 - 12.6 Volts. Turn the car on and turn on the headlights, radio and air conditioner. You should be getting around 14.4 Volts. If not, then you may have a problem with your charging system (bad alternator/voltage regulator, wires, etc.)
