'08 Armada Fuel Requirement
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
SFBayQ45
Car: cars
Does the refreshed Armada still take regular unleaded? I know the '07 uses regular, however is there any difference/increase in horsepower or torque in the '08 that requires higher octane (similar to that of the QX4 refresh in the past)? I like the QX56, but the premium requirement is a big turnoff considering gas prices these days. In that aspect, the Armada is a good alternative for the same size and ride. While I'm on the same subject, is there a way to de-tune the QX56 engine to make it run on regular gas instead (so as to prevent the "knocking" associated with using 87 octane)?
vestigeKA24
Car: u13
SFBayQ45 wrote:Does the refreshed Armada still take regular unleaded? I know the '07 uses regular, however is there any difference/increase in horsepower or torque in the '08 that requires higher octane (similar to that of the QX4 refresh in the past)? I like the QX56, but the premium requirement is a big turnoff considering gas prices these days. In that aspect, the Armada is a good alternative for the same size and ride. While I'm on the same subject, is there a way to de-tune the QX56 engine to make it run on regular gas instead (so as to prevent the "knocking" associated with using 87 octane)?
yes it still does
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Yes, the 2008 does take REGULAR unleaded gas. In many parts of the country the Armadas and Titans have a Flex Fuel engine. So you can also run E85 in them if you have the FF engine. So that is a bonus if you are in one of those regions, and if you have an E85 station near by.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
