I've searched and searched for this issue and haven't really found any definitive solution.
Over the past couple of years I've had to replace my alternator 3 times (not an easy job on this vehicle). I first replaced the original alternator with a re-man one from O'reilly that has a lifetime warranty. This one lasted for about a year, all of this time I had an issue with my headlights randomly dimming. I replaced it and the new one lasted for about 6 months until the brake and battery lights came on on my way to work. My battery didn't have enough juice to get my car out of the parking lot on the way home. It turned out my battery was bad, so I replaced it, but the brake and battery lights were still on. I got the alternator tested and it was also bad. I replaced the alternator again, and the lights went off.
It has been less than a month since I put this current alternator in. Now today on my way to work, my brake and battery lights began flickering, signaling that the alternator is going bad (again).
What could be causing these alternators to fail so frequently? Are the re-mans just that poor of quality or is there some other issue that could be causing it? I'm sure that I'll be spending another 4+ hours to replace the alternator again soon and if it means not having to do it again, I'm prepared to buy a new (non re-man) one.
Thanks for the help!
