jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Mon Nov 04, 2013 7:25 pm
for the same options the Z and G will have the same wiring harnesses. literally the only difference between the two is the two rear seats/slightly longer and springs. they are the same car other then that built on the exact same platform so whoever told you that likely was talking out their a**. now i have seen alot of nissans(the infiniti is a nissan dont let anyone fool) you with ipdm, bcm, and even brake module issues.
if you plan to mod for any decent amount of power get the G for the de engine and better parts availability, otherwise the HR
be aware again since i have no idea what your plans are that the auto trannys are weak as hell vs the 6mt, fully built stage 3 transmission which is 4k cant handle more then 550 whp, the 6mt's stock have proven themselves to well over 1000 hp, sound performance ran 1250 whp on theirs and it held up. didnt have a issue till they put 28 inch tall slicks on and broke a input shaft, replaced with latest revision cd009 and no problems. now the previous revisions(06 should have a cd009) had syncro issues but drilling the locating holes allows running the revised syncros.
G is also a couple hundred lbs heavier
