The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Wed Apr 09, 2014 3:09 am
That is not an issue, what other cars have you owned? The only reason the RPM wouldn't drop when going down hill with cruise control would be if the car was actually resisting gravity to such an extent that the engine needed to continue to push to maintain speed. IOW, I have to guess you were driving maybe a Jeep or something else with a beastly transmission before, or perhaps had four bad wheel bearings on each of your previous cars? Realistically, while some manufacturers would clearly beg to differ, one shouldn't expect a car to slow down just because his foot came off the gas IMO (that's what brakes are for). Presumably your previous cars slowed down much quicker than the M45 when you took your foot off the gas. My previous cars all coasted much better than the M45 and gained free speed going down hill. What's annoying with the RPM and cruise control on my 06M45 is that it has to keep jumping back up after dropping while going down hill because it is geared so low there is always a bit of engine braking. None of the three cars with cruise control that I owned before the M ever did that, because they had decent gearing and could actually coast.
Regarding going uphill, depending on the hill, this is normal if annoying (especially considering how low it's geared). However, you might search for instructions to reset your ECU and manually drive up some hills while trying to maintain speed without shifting. It can be done, and as the ECU learns your style, the cruise will start to fit your style a little better. Unfortunately, for bigger hills, this won't work. My previous cars would do this on some hills, but since the pedal moved with the cruise control, I could actually apply a little more gas in anticipation of the hill in order to prevent it. It is possible to do the same thing in our M45s, but it is trickier since it is drive-by-wire and the pedal isn't already in the current throttle position. Because of that, if you don't push it far enough, it will slow you down (at least with intelligent cruise active), and you won't feel when you get to the sweet spot, so you can easily push it too far and cause the same downshift yourself anyway.
Regarding the downshifts when stopping, this is normal, but if it seems a bit much, maybe you need to change your transmission fluid and/or differential oil. At 44,000 miles, you might even be OK flushing the transmission, but I don't know with the age on the fluid. Depends if you believe that transmission flushes can cause problems, I guess.
