07 Versa Manual transmission Oil Change
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
arangurencg
Car: 2007 Nissan Versa 6spd
I can't find the oil that the manual calls for, could I use the next weight above or bellow? Also what are your thoughts about going fully synthetic??
Thanks.
arangurencg
Could 75w90 w/o damaging anything????
Francesco
I have an 09 and had to get the oil from a dealer. I believe the important item is to use GL4 type rather than GL5 since there have been some problems with some GL5 oil attacking the metal on the synchronizers in the transmission.
Frank 2009 Versa S MT-6 with 31K miles
didier
Car: Nissan Tiida ST-L 2006(Japan)
MR18DE
I'm currently using Castrol Manual Syntrans 75W85. It's fully Synthetic oil and was recommended to me by the Nissan Dealership.
mitchellhuth
Car: 2010 Nissan Versa S 1.8
I use AmsOil, not sure the viscosity but I made sure it was GL-4. It works better than original.
Return to “Versa Technical Discussions”
