Kingdom934 »
https://forums.nicoclub.com/kingdom934-u103798.html
Thu Jul 01, 2010 2:40 pm
EDIT: Engine seems to be running normal. No noticable peformance drops other than the noise. I checked the oil and didn't notice any drops either.
I've tried driving around a little w/ AC running. Noise still occurs. Occurs when slowly reving (I.e. Hold in L until 2,800 and then 2) and when downshifting (say your in 'L' down a steep hill). I'm assuming this happens under normal driving revs, but I can't hear it. Also happens if your in that range from going up a hill. I can't hear anything going downhill, but thats likey because theres no load on the engine.
I noticed that the noise is very noticable (especially when you got like a wall or something next to you so the noise bounces back) @ 2,600RPM. When I'm in my garaged, I can hear the noise any where from 1,800RPM ish ~ 2,800RPM ish with the 2,600rpm being the most rattle/knocking.
It seems to be related to engine speed also. When I'm say in park idling at 2,600rpm with my foot slightly on the gas to maintain that speed, I can hear the noise, but if I step on the gas, for the split second when it revs up to a higher rev, the noise speeds up and disappears either because the engine is too noisey already or it goes away.
Gonna be doing my oil change and going to look for any metal particles in the oil.
