sooner4x4 »
https://forums.nicoclub.com/sooner4x4-u71453.html
Wed May 14, 2008 5:38 pm
My thoughts on what needs to be done at 15k:
Oil change: it depends on when the last one was done. An oil change may not be needed at 15k.
Air filter (engine and cabin): do it yourself. This is a no-brainer. I believe the book does recommend a 15k interval for this. Most other modern cars I have owned have a recommended service interval of 30k for air filters.
wiper blades: I do this once a year, regardless of mileage, so this may or may not occur every 15k.
Tire rotation: do it yourself. Depending when the last time you did this, it may not be needed at 15k.
Inspecting and lubing stuff: Do it yourself. Come on, do you really believe the dealership actually checks all of this stuff? I have serious doubts.
Handing over a few hundred bucks every 15k seems ridiculous to me. If someone has a few basic tools and common sense, most basic maintenance can be done yourself with way more quality and care and attention to detail than some hurried up technician at a dealership would do. For a lot less money.
If someone knows absolutely nothing about cars, they should read the manual, and insist and only pay for the necessary maintenance items. To do otherwise is to be ripped off. IMHO.
My V currently has 14,200 miles, fast approaching the 15k mark. It just so happens I will need an oil change by then. I will also replace the air filters. If they aren't all that dirty, I will extend the air filter replacement longer next time. I rotated my tires at 13k so that won't be necessary. Nothing else will be needed. Total cost: Approx. $44
