07 projector will they work on a 03 coupe
blueg1
hello, i have a 03 coupe and i got a pair of 07 projectors that im going to install. i just noticed that fog/high beam set up is diferent.. the 03 uses a d2r for the low beam and a h4 for the fog/high beam combination. the 07 headlight uses a d2s for the low/ and high and a h1 for the fog. my question is will it be a plug and play convertion and is the ballast the same?
i will apreciate any info.
thanks
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
Welcome to NICO. I can't answer whether the 07 will sub to the 03, but this is the place to ask. I might suggest you search (the large button at the top left) for a possible answer while you wait for others to respond.
Before and after pics would be welcome if you do it.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Yup ballast is the same it's 100% plug and play.
G_whizz
Car: 2010 G37 Coupe Sport
Welcome to NICO!!
blueg1
so how does the 1 d2s bulb work for low and high beam?
cde2k7
Car: 2007 Serengeti Sand G35S AT Sedan - Prem - Nav
From Wikicars.org:"Bi-Xenon Headlights refers to HID (High Intensity Discharge) Xenon headlights that offer both low (dipped) and high (main) beam lighting from a dual headlight system (as opposed to a quad headlight system).A bi-xenon system eliminates the need for a separate halogen high beam bulb/lense by either moving the xenon bulb within the lense or by moving a shield up or down in front of the bulb (depending on the reflector design) to allow light to escape from the lense in a different pattern."
URL: http://wikicars.org/en/Bi-xenon_Headlights
Floppydiskz
Car: 04 G35 Coupe
I just finished the 2007 conversion today on my 04 g35 coupe.
I must say I am very satisfied with the results. Much Much brighter and covers more ground than the 2004 lights.
Modified by Floppydiskz at 11:40 PM 3/4/2008
smockers83
Car: 2006 G35 Coupe
You had to post one with a navy blue G...god I hate you now
I wanted a navy blue one so bad, but they discontinued it. So I had to go with red.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
just a heads up...
that link is to a different forum...do the write up yourself (if you took pictures)
generally frowned upon when you link to a different forum
Floppydiskz
Car: 04 G35 Coupe
tollboothwilley wrote:just a heads up...
my apologies. Link has been taken down.
