HELP 07 patherfinder startup Problem With vid!!!
abhele408
Car: x altima coupe owner
now have a 2007 graphite gray g35
i try to start it and it wont start and and all the gauges start to flash and i turn the key and and engine is making a radling sounds. Can anyone help what it can be.
also here is a video i made!
http://www.youtube.com/watch?v=wIWvy5CFK18
ARKQX33V6
Your video is of very little help, but I can guess, if that might help!
Light blinking, if you are not turning the key switch relays moving on / off, time deay, ground make/ break, or supply power being interrupted
Noise under hood sounds like a fan blade being hit while in motion, have I got the sound correct?
Like I said only guesses
drnkirishm
Car: 2001 QX4
Sounds like your battery doesn't have enough juice to turn over the engine or the starter could be bad. Do you have an ohm reader to test the voltage on your battery? If not you can take the battery to an auto parts store to see if its good or not.
Pathy415
Car: 2002 Pathfinder LE 4WD
I agree with checking the battery and then checking the starter. Did this problem just happen all of a sudden or did you have issues prior to this?
