07 Murano S Tire Pressure Warning
Forum for the unique Murano, and official home of Nissan Murano Club!
Ltam
Car: 2007 Murano
Hi,I hopped into my Murano this morning and my check engine indicator was on. I checked the maintence button and found that the Tire Pressure system says there is 0 psi in one of my tires. I manually checked my tires with an electronic tire gauge and all tires have sufficient air (40 psi). Anyone else with this issue or know how to fix it without taking it in to the mechanic?
5jones
Car: Nissan Murano 2007
I had the same problem and the dealer replace the sensor. You would take the car to the dealer to reset the sensor, if the sensor is bad they have to replace it. If you change the sensor by your own you will have to take the car to the dealer to register the new sensor in the car computer.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
5jones wrote:I had the same problem and the dealer replace the sensor. You would take the car to the dealer to reset the sensor, if the sensor is bad they have to replace it. If you change the sensor by your own you will have to take the car to the dealer to register the new sensor in the car computer.
Welcome to NICOclub 5jones!!! Glad you are here and we hope you enjoy the Murano forum!
Return to “Murano Forum”
