07 maxima all interior lights out, radio, ac , fuel lid switch, gear stick
Picklepepper23
Car: 2007 nissan maxima
I have a 2007 maxima se. I was driving 2 days ago and the radio station i was listening to went out for about 2 sec then came back on.... then couple minutes later all lights went out.... dashboard lights, radio went out, all interior lights... fuel lid button doesnt work... ac is out. Then couple minutes after that everything went back to normal and lights came back (without me doing anything ). Eventually it happened again and this time it didnt come back on... so i pulled over to check it out and see whats wrong... go to put the car in park and the gear stick would not move into park.... i had to take out the piece and put it in park manually.... figured it was a bad fuse.... but all the fuses are working properly. I then thought it was something behind radio short circuiting.... i tried both driving with the cllumate control and radio disconnected and problem still keeps reoccurring. When it goes out gear shift wont move from park or go back into park unless i use screw driver and do it manually...
Anybody ever experience anything like this? Its driving me crazy
Windering if its something that controlls all those things (module) or maybe a short somewhere?
Could the alternating be shutting down certain electonics to protect them??
Any help would be appreciated.
Picklepepper23
Problem solved. Thank you for suggesting battery connection. It turns out my positive battery terminal (2007 maxima has fusable link) was all burnt out and had to be replaced. Which isnt visible unless you go to change the terminal.
Hope this helps if anyone is or ever had similar issues.
