07 maxi heat seat
anthonyflame
any bros can tell me how to change the heat element on bottom and back seat(passenger side) bcoz my heat element is dead. Dealer charges me 1200 to fix it.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
I'm assuming your basic warranty (3-yr/36K miles) is over. Still, that's too early for a simple heater plate to fail. Have you check the fuses, Heated Seat relay and connectors? Below is the link to FSM (Factory Service Manual). Go to page SE-96 (Seat section) for seat assembly, SE-85 for description and SE-88 for wiring diagram.
http://www.nicoclub.com/FSM/ma...e.pdf
anthonyflame
loystock wrote:I'm assuming your basic warranty (3-yr/36K miles) is over. Still, that's too early for a simple heater plate to fail. Have you check the fuses, Heated Seat relay and connectors? Below is the link to FSM (Factory Service Manual). Go to page SE-96 (Seat section) for seat assembly, SE-85 for description and SE-88 for wiring diagram.
My car was passed to Nissan dealer and thorough check they found the whole passenger side should be replaced by new heat element but I check the heat element just less than 100.00 but they quote the cost of repair 1,200 to 1,400. I thought I just fix the bottom rather entire system. Any idea?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Check with NICO sponsor, Ios (Infiniti of Scottsdale) - infinitipartsUSA.com a.k.a. 'everythinginfiniti.com.' They sell OEM parts for @ 25% off MSRP. Joe Tesensky and his staff should be able to help you. They are very knowledgeable about Nissan/Infiniti parts. I buy most of my parts there.
anthonyflame
loystock wrote:Check with NICO sponsor, Ios (Infiniti of Scottsdale) - infinitipartsUSA.com a.k.a. 'everythinginfiniti.com.' They sell OEM parts for @ 25% off MSRP. Joe Tesensky and his staff should be able to help you. They are very knowledgeable about Nissan/Infiniti parts. I buy most of my parts there.
thank you so much for your information but i donno is it very difficult to do it myself. Any idea?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Seat heater is a nice feature to have, especially during winter. But it is something you can live without. So you can set aside a weekend to look deeper into the problem. I still cannot believe that a simple heater plate will fail this early. Usually, it's just a matter of having a loose connection that causes the problem. I know Nissan already did a diagnostic but there is no harm on doing it on your own. If you know how to use a multimeter, you can compare the resistance of the driver-side heater elements (good) with the supposedly bad pax side heater. Refer to page SE-84 for the basic seat heater location, then SE-88 onwards for wiring diagram and then SE-96 onwards for the actual seat heater installation.
WATCH OUT for air bag connectors (usually with yellow wires) on the seat. You have to make sure the batery has been disconnected for at least 3 mins before working on the seats. Do not do any resistance test on those connectors. Please refer to precautions about air bags
anthonyflame
I have same idea. One import thing I have to mention. Last summer I installed HD Radio and opened the console and dash board. Do you think the wire come along the console to the bottom of seat?
anthonyflame
loystock wrote:Seat heater is a nice feature to have, especially during winter. But it is something you can live without. So you can set aside a weekend to look deeper into the problem. I still cannot believe that a simple heater plate will fail this early. Usually, it's just a matter of having a loose connection that causes the problem. I know Nissan already did a diagnostic but there is no harm on doing it on your own. If you know how to use a multimeter, you can compare the resistance of the driver-side heater elements (good) with the supposedly bad pax side heater. Refer to page SE-84 for the basic seat heater location, then SE-88 onwards for wiring diagram and then SE-96 onwards for the actual seat heater installation.
In the back you can feel the heat but bottom nothing.
