The best way for us to help you is to give us the code(s).Waders wrote:My M45 just started misfiring.....What do I check first? Is there anyway to see the codes without the obd2 scanner, I know how to reset the ecu but is there a way to see codes...
Not sure about the catalyst, but as far as OBD-II blinking out codes, it absolutely does. On my 99 Maxima, without a code reader, what you used to have to do is turn a screw on the ECU and it would blink the code for you.cjcarbone wrote:The check engine light blinking means that there is damage to the catalyst likely- obd2 does not blink out codes.
cj is correct. A light that flashes while driving indicates a critical condition in which continued driving is not recommended.steve_c wrote:The best way for us to help you is to give us the code(s).Waders wrote:My M45 just started misfiring.....What do I check first? Is there anyway to see the codes without the obd2 scanner, I know how to reset the ecu but is there a way to see codes...
Basic OBDII readers are cheap, you can pick one up from any auto parts store!
You might even be able to borrow one from a parts store to check your codes.
If your light is flashing, that could indicate a critical fault may exist, and that you might be doing harm to the engine and /or its components driving under those conditions.
It's not terribly hard to change most of the sparkplugs on an m45 and although I can do it blindfolded, it's still not my favorite pastime. Also, replacing sparkplugs isn't a bad idea at all at a certain mileage, but at around 80 Dollars for parts, why do it if you don't have to?Waders wrote:Just went and started the car and it sounds fine, no misfirintg. I took off the neg battery last night and started it. Im not sure what to do, probably sure it might be a coilpack or spark plug. Ive ordered some spark plug but I dont know if its a hard job changing them. Might just take it to a mechanic when i get the spark plugs
Easiest thing to do to see if it's a coil (which it probably is) is swap coils to a different cylinder and see if the misfire moves with it.Waders wrote:Update: I drove the car this morning all was fine, but when it reach normal temp it started misfiring. It sounds like a boxer engine, so I brought it to the mechanic and he said if the cel lights flashes its usely a misfire. So hes gonna plug it in for codes and we will see from there. Ive ordered a set of plugs to get them changed. Might be a plug might be a coilpack. The misfire only occuring at normal temp and not when cold makes me think it might be a coilpack. Had the same problem with my Gtr. Ill let you guys know what happens, it might help some other guy having the same problem in the future.
Absolutely. If the coil is weak/inop, then the cylinder is dead or weak, which means it's sister cylinder is dragging the weight of an unfired piston. On a small displacement V8, it can be really drastic feeling.Waders wrote:Update: It was the coil on #7. Put in a new one and now it runs great. I always felt the car had a little stutter or a little loss in power, but now I dont feel it anymore. Is it possible that the coil was doing this, just before it failed? it might just be a placebo but it seems to run much smoother now.
