07 M35 seat climate control TED question
sammysquest
Car: 2007 M35
2002 G20
2000 I30
I have a 07 M35 that the climate controls on both front seats has failed. Im assuming the TED assemblies have failed and if anybody has has success replacing the TED's on the seats. The fan and filters are not part of the problem. The console temp adjustment controls open the safety fuses and the power drops out until the safety resets. Anybody replace or repair with aftermarket items.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I dunno about aftermarket, but I just replaced a pair of them on a Titan where the fan quit and overheated both Peltiers. They aren't difficult to replace, although the seatback unit does require knowing your way around upholstery. Otherwise it's a zip-tie job, nothing special. Your real problem will most likely be parts, the seatback elements are discontinued and I don't see any aftermarket ones. So you might need to kluje a seat cushion unit into the seatback. There's actually one OE cushion unit on eBay for $25:
https://www.ebay.com/itm/185340748810
sammysquest
Car: 2007 M35
2002 G20
2000 I30
Thank You
Ill post an update once I see if I can adapt another TED from another auto
Sacto Infiniti
Car: 2007 Infiniti M35x
One of my seats failed, the TED unit I bought didn't fix the problem. The other works fine, any ideas?
