infiniti650 »
https://forums.nicoclub.com/infiniti650-u259468.html
Mon Dec 14, 2015 3:52 pm
Adding to an old, but valuable thread...
So my '07 M35 started having intermittent issues as well with the blower/fan in all modes - Auto, defrost, manual fan. Googling around, found the old threads about a Blower Fan Resistor on older (generally pre-2006) nissan/infinii. Then this thread, and one about a G35 on another forum. Long story short. These "newer" nissan/infiniti have a relay for the blower fan instead. And it is a good place to start, because it isn't so bad to replace.
Because of the centralized/integrated climate control on these cars, it may be something else, i.e. there are 4 or 5 sensors in the car to determine temperature, ambient temperature as well as tying into the heater core thermostat, so it might be something else, but the relay seems to often be the culprit. In my case, my fan might come on when the engine heated up sometimes, but it would just as often not work, when the engine was hot, which is why I didn't believe it was the heater/coolant thermostat.
Sorry no pictures, but using the FSM on Nico and the index (idx.pdf) and searching for interior fuse block, blower fan relay, front kick/kicking plate was enough to find necessary info. So the procedure was:
- Buy a blower relay: 25230-79942 , same part number for Nissan and Infiniti. I got it for $35, but there are generic for $25-30
- Find your interior Fuse Box/Block. On 2007 M35, it down by the driver's left leg, left of the parking brake
- There is single, black nut, just above the dead foot pedal. Remove it.
- Now the rest are snaps
- Remove the Sill Plate (has lit infiniti on it). Nissan/infiniti calls it a Kick Plate, or Kicking Plate; it is L shaped and holds down carpet. There are 3 snaps - top left, middle, back right, as you face into car. You lift up. I used a screwdriver to pry it up. Have to pull fairly hard.
- Once you remove that, then you can remove the carpet/plastic cover over the fuse block. 2 more snaps on side opposite of screw. "pull" towards interior of car.
- With that out of the way, you can now contort yourselft to remove the Fuse Block/box. There are 2 screws/bolts on top. Don't remove the screws underneath; they're for box under Fuses. On the bottom of the Fuse Block, it slides over a metal plate with a plastic tab. Need to use a screwdrive to pop tab, and wiggle Fuse block out. Tip: I used a socket wrench to remove bolts. If you put some tape into the socket, it will hold bolts and not drop them as you take them out, and put them back
- With Fuse Block pulled out a bit, you can turn it over. For the M35, on the back of the Fuse Block there are 2 blue relays, the blower relay is the furtherest one back, or on the "right" as you are facing the Fuse side of the Fuse Block. if you check your Fuse diagram, the relay is behind the 2 15Amp fuses labeled Fan on the fuse diagram.
- you can wiggle/pull out the blower relay. No tabs, but will take some wiggling.
- Replace with new relay. Then start your car, and test the Climate Control. It all worked.
- Now just put everything back, and you're done
- Took about 20-25 minutes to take everything out, since I was moving slow and careful. About 5 minutes to put it all back together again.
- Tools used: screwdriver, metric socket, socket extension, socket wrench.
