07 M35 Battery going dead overnight.
Wiggeizig
Battery keeps going dead. When putting an Amp meter on it, it only draws 0.01-0.05 amps. Replaced Audio Unit and replaced battery, still having problems. Any ideas??? Thanks.
szh
Car: 2018 Tesla Model 3.
Hmmm ... does sound like some problem somewhere in the electricals - something is staying on clearly (or a short?).
Although, if the current is that low, then the battery should be fine for much longer than overnight for sure!
Is the alternator and/or relay working properly and charging the battery normally when the car is on?
Z
