rg_g35x »
https://forums.nicoclub.com/rg-g35x-u62934.html
Sat Jun 23, 2007 9:51 pm
I've noticed that when shifting in manual mode that the 1-2 shift is 'lazy' the higher the RPM's are. Even about 4,000 RPM's it shifts slowly - not as much that it 'reacts' slowly (it starts to shift pretty quickly after I move the shift lever), but a very slushy and slow shift into 2nd gear. In auto (DS or D) the shift is quite quick a firm. I would think the manual mode would be the quickest and firmest shift - more of a 'sport' mode. If I almost redline it in 1st (in manual mode) then there's a real hesitation as it lazily shifts into 2nd. Shifting into 3rd (and higher gears) is quite quick a firm, though.
I was going to post a video, if that would help explain it (let me know if it would help, and if it would where I can post the video and link into it here.)
I was going to mention this to the deal when I take it in for the first oil change, but thought I post up here to see what everybody here thinks, and particularly what others with 07 G35X's experience is.
One last thing - there only seems to be 100-200 RPM difference between 4th and 5th gear - that seems really odd to me? If I watch the tach as I shift from 4th to 5th, it only drops 100-200 RPM - now this isn't going very fast, so I'd expect a bigger difference at higher speed, but still it seems like pretty close gearing to me. I would expect close ratios in the lower gears and wider ratios in higher gears for a better performance/fuel economy mix.
